Replaced Intake Gasket Now Misses
Old Oct 11, 2009 | 04:13 AM
smrtnez99's Avatar
smrtnez99 is on a distinguished road
Default Replaced Intake Gasket Now Misses
I have a 1999 Blazer with 118,000 miles on it. It was running fine no overheating but I noticed engine coolant leaking after short trips around town. Found where it was coming from and determined i needed to replace the lower intake gasket I put the distributer back exactly where i marked it, the engine was not moved. I put everything else back to how it was and filled it with coolant. When I tried starting it all it would do is just crank over. Then I poored a little bit of gas in the throttle body while holding it open. Waited a for a minute then tried to turn over and it finally came to life with hesitation. After doing this a couple times it starts on its own like normal, but misses at idle and when i accelerate it. And the service engine soon light came on with P0300 code.
Could I have gotten the fuel injectors dirty(spider)??
Old Oct 11, 2009 | 06:59 AM
reelbroke2's Avatar
reelbroke2 is on a distinguished road
There could be several things,Are the plug wires in the proper order? check spark plugs (fouled)? all sensors hooked back up (cam sensor)? proper torque of intake gasket? i have also seen when the spider has been disturbed that it can leak,do you smell gas?
spiderbalze
Oct 25, 2011 09:40 AM
drew_fur
Jun 8, 2011 03:52 AM
kermit1112
20
Jan 21, 2010 11:20 AM
polecat
Mar 29, 2008 07:45 PM
greenclover19
Mar 26, 2008 03:13 PM
