replaced intake manifold gasket now it backfires help!
Old Mar 29, 2008 | 05:38 PM
polecat's Avatar
Member
polecat is an unknown quantity at this point
Default replaced intake manifold gasket now it backfires help!
Ok so in my 98 blazer I just got done replacing the intake manifold gaskets, oil cooler lines, spark plugs and wires, distributor cap and rotor button. The problem is now that I have everything back together it is hesitant to start and once running the fan runs all the time and it backfires every few seconds it also is running a little rough it also smells a little of raw fuel out of the exhaust only thing I can think of is the distributor is off but I'm not really sure what else it could be any help would be greatly appreciated
Old Mar 29, 2008 | 05:40 PM
Jharper's Avatar
Jharper is infamous around these partsJharper is infamous around these parts
Default RE: replaced intake manifold gasket now it backfires help!
welcome to the forum, you might want to post in the corect section of the forum for your issue.
Old Mar 29, 2008 | 06:03 PM
polecat's Avatar
Member
Thanks for the advice I tried but this is the only section it will allow me to create my own post in
Old Mar 29, 2008 | 07:00 PM
riceh8r0512's Avatar
riceh8r0512 is an unknown quantity at this point
Are the wires in the right firing order? Is it throwing any codes?
Old Mar 29, 2008 | 07:19 PM
*Moving to 2nd Gen Tech*
There are no restrictions on new member posting... You should be able to create a new post in any section that you can see.
Old Mar 29, 2008 | 07:26 PM
polecat's Avatar
Member
as far as everything that I have seen the spark plug wires are in the correct firing order i have the plug wires hooked up in order starting at the front 1 - 3 - 5 on drivers side and 2 - 4 - 6 on the passenger side but what is it just in case I have it wrong and thanks swartl i must have just missed or something i was in a hurry when i posted this
Old Mar 29, 2008 | 07:43 PM
I believe that it goes 3-1-5 on the cap though... Were you connecting the wires per the numbers located on the top of the cap?
Old Mar 29, 2008 | 07:45 PM
polecat's Avatar
Member
ya I just went out and checked it the plug wires are connected exactly according to the numbers on the cap and it is 3 - 1 - 5 on the drivers side sorry I was going off of memory
drew_fur
Jun 8, 2011 03:52 AM
Shalom
Aug 1, 2010 01:49 PM
ChevyFamily
Jun 9, 2010 11:07 AM
kermit1112
20
Jan 21, 2010 11:20 AM
greenclover19
Mar 26, 2008 03:13 PM
