Replaced Vacuum Lines - Now Rough Idle
Old 11-08-2010, 04:32 PM
keego's Avatar
keego is on a distinguished road
Default Replaced Vacuum Lines - Now Rough Idle
I replaced 2 vacuum lines on my '99 blazer. I had to take the breather assembly off to get access to the rear of the manifold. I unplugged the MAF and another sensor just behind it. (what is that one anyway?) When I put it all back together and started it up, it seems to idle fine except every few seconds the rpm's drop for a second, like it's going to stall, then it goes back up to normal idle. It keeps doing this and even when I drive it, it seems hesitant to go from a stop. Anything?
Old 11-09-2010, 04:21 PM
keego's Avatar
I just wanna bump this cause I really need help.
Old 11-09-2010, 06:09 PM
Are you sure everything is connected back up properly? Have you double/triple checked everything you messed with?
The sensor behind the MAF is the IAT (intake air temp) sensor.
klote82
04-27-2012 08:22 PM
jasonscottclack
05-25-2011 07:03 AM
Electrode
12-13-2010 12:51 PM
ohsofly
50
02-22-2010 01:52 PM
greenclover19
03-26-2008 03:13 PM
Quick Reply: Replaced Vacuum Lines - Now Rough Idle
