replacing fan blade on '96 4.3 v6
Old Oct 23, 2007 | 02:08 PM
nullmer's Avatar
nullmer is an unknown quantity at this point
Default replacing fan blade on '96 4.3 v6
So, my fan blade shattered, and I'm in the process of replacing it, but I can't figure out how to loosen the large bolt that holds it to the water pump... any help?
Old Oct 23, 2007 | 02:13 PM
Default RE: replacing fan blade on '96 4.3 v6
A special tool is available to make this job a lot easier, but I was able to do it with a pry bar and my large adjustable wrench. The trick is finding the sweet spot for the pry bar so it won't overly restrict the loosening force you are exerting on the hex.
One other thing that I have been able to do in rare occasions is put a breaker bar into the tensioner in the square hole provided and actually tighten the belt more. This is more of a two person ordeal though. One to hold the breaker bar on the tensioner while the other holds the wrench on the clutch and hits it with a hammer. Often the shock of the hammer impact will loosen the clutch pretty darn quick.
Old Oct 23, 2007 | 02:52 PM
nullmer's Avatar
thanks for the quick reply... the hex is reverse threaded, right? also, I have an old metal fan from a junkyard thats in really good shape... I was hoping that it wouldn't really make a difference since the bolt patterns look the same.
Old Oct 23, 2007 | 02:55 PM
Regular right handed thread. And a metal fan will make a difference in the amount of power it takes to get the same airflow. The plastic fan is much more efficient of a design than the metal fans, not to mention lighter!
If you can find a plastic one in a junkyard, that would be the place to get it. eBay also has a few for not too much coin... I searched for 'blazer fan' and turned up atleast 3 results.
needshelp
Nov 19, 2013 07:39 PM
Tippman7641
14
Feb 21, 2008 10:57 AM
lionel2
Feb 17, 2008 02:06 PM
zerokarma
Oct 18, 2007 02:44 PM
speeddemon560
Engine & Internal
Feb 16, 2007 12:47 AM
