rid of antifreeze smell
Old Sep 29, 2013 | 05:34 PM
dpmeeks's Avatar
dpmeeks is on a distinguished road
Default rid of antifreeze smell
I had the joy of changing out the heater core in my blazer a couple of days ago. Is there a easy way to get rid of the antifreeze residue smell coming out of my vents ?
Old Oct 2, 2013 | 12:31 AM
WalkGood's Avatar
WalkGood is on a distinguished road
Blower on high, a/c on, but not MAX. Windows open, heat on hottest. Alternate with cold. Let it run for a loooooooong while. Or go for a long drive.
Could try Febreze spayed into air intake at the cowl.
Old Oct 2, 2013 | 07:13 AM
dpmeeks's Avatar
thank you,, ill give it a try..
Old Oct 2, 2013 | 07:39 AM
toyhauler1283's Avatar
toyhauler1283 is on a distinguished road
What year is your blazer and how long did it take to do the heater core. I have a 97 4wd 4dr thanks.
Old Oct 3, 2013 | 07:02 AM
dpmeeks's Avatar
mine is a 98 and it took me about 4hrs, its not that bad to do.
Old Oct 4, 2013 | 01:15 AM
step66's Avatar
There is a system that the dealership I work at is using with good results. It is called CHI. They are raping the customers for this service,but the results are impressive! Witnessed many horrible stinks from the HVAC system disappear! Also helps if you properly clean the interior as well. Retail(list) at my dealer is $90. Seems to work best on newer units with cabin filters and high pressure systems and superior cabin sealing,so I can't endorse it for a Blazer,but give it a thought!
Old Oct 4, 2013 | 01:20 AM
richphotos's Avatar
look up ozium airfreshener spray... spray that into the fresh air intake on the cowl, into the carpet padding ect, a couple times at the most with that and it should clear it out right away.
Its like febreeze on steroids.
A Perry
14
Mar 1, 2012 10:32 PM
jpmccr
Oct 21, 2009 09:22 PM
FImports
Detailing
Feb 28, 2007 11:33 PM
97blz4x4
Nov 16, 2006 08:50 PM
kdanderson5
May 5, 2006 11:35 AM
