Right turn Clyde
Old Oct 31, 2017 | 06:36 PM
Hate this blazer's Avatar
Hate this blazer is on a distinguished road
Default Right turn Clyde
I have a 1998 blazer LT, on top of the brake problem I posted about, I have a turn signal issue. When I switch on right turn it blinks as if a bulb is blown, but both front bulbs and the rear were good. I even switched all bulbs to the left side and lefts to the right and still left side flashing quickly, and all bulbs working. After eliminating bulbs, cleaning connections and inspecting for loose or pinched wiring, all I can think is it must be in the switch itself. Both signals work from the same relay, so switch or something I'm not thinking of? Thoughts?
Old Nov 1, 2017 | 08:36 AM
LannyL81's Avatar
Yeah probably in the switch itself or the wiring within the steering column. This is going to take some time and patience to track down especially if within the column.
I would start with the large connector at the column base, make sure all wires are good there first.
Old Nov 1, 2017 | 10:03 AM
Was afraid of that, I may have done something putting the booster in as well, as you know it's pretty tight under the dash especially with bolts behind steering column. thanks for replying.​​​​​​
Old Nov 2, 2017 | 04:39 PM
GreenBlazer2002's Avatar
You might also replace the flasher module. They're cheap enough.
Old Nov 2, 2017 | 11:24 PM
Default Problem solved thanks everyone
lannyl81 good call on this one as I was checking wiring at the column I found that a wire from the connector you spoke of had a couple wires almost pulled out of the connector. I think they were making just enough contact to work or maybe even had power jumping a short gap causing the fast flash, but all good now thanks. I suspect I may have done this removing or installing brake booster.
Old Nov 3, 2017 | 08:32 AM
LannyL81's Avatar
Good to hear that it was the simple fix and not the multi-function switch needing replacement....those a real PITA to do.....getting the large connector down the steering column usually requires taking alot of parts out.
Old Nov 4, 2017 | 05:17 AM
Default Sure is
I helped a friend replace a multi function on his 95 and not only was it frustrating it was expensive. What happened to simple mechanical parts and pieces that seemed to last twice as long and cost pennies compared to today's electronic crap. I blame laziness, I mean convenience, sorry.
Old Nov 7, 2017 | 08:08 AM
LannyL81's Avatar
Fully understand and agree.
matthp
Nov 17, 2009 11:02 PM
boscoedoodle
Nov 3, 2009 12:33 PM
ta3ff
Oct 14, 2009 05:07 PM
kikkegek
Tires and Wheels
20
Oct 12, 2009 08:04 AM
redpeppers
Apr 7, 2007 04:55 AM
