Rough Idle
Old Nov 16, 2022 | 01:47 PM
jimmy_for_ever's Avatar
jimmy_for_ever is on a distinguished road
Post Rough Idle
Hello everybody
I have problem with my 2WD 00 Jimmy it runs Rough in Idle but the rpm stable at 620 . Recently I change the brake booster with new one because I was think it is because of vacuum leak from it now the car run better but it is still it run Rough and I can feel the vibration of the engine. I replaced the injectors with new upgraded one before 3 years and the tune up include motor mounts was done before 6 years ago.
What can cause this problem ?
thank you
Old Nov 16, 2022 | 02:04 PM
GeorgeLG's Avatar
This can be so many different things. Its definitely solvable and some get lucky and guess right early on but most need to go through a detailed diagnostic flow to find the problem and address it. Broadly speaking it can be:
Fuel delivery/air
Ignition
Sensors, electrical/PCM
Engine mechanical issues
We first look at codes or ask for other symptoms to help pick a logical starting point so we don't just have to plow through the whole universe of possibilities randomly. Before we get started, are there:
Any codes
Other symptoms
Recent work that made it better or worse
A recent compression test
A recent fuel pressure leak down test
Inspection for exhaust leaks
A look at manifold vacuum
George
Old Nov 17, 2022 | 12:32 PM
Hi GeorgeLG
No codes there. I don't know how to test the fuel pressure leak down and manifold vacuum do you have any articles or video on how to check. Also, I have one question about spark plugs when it should be changed ? because my spark plugs color changed to black.
thank you
Bepjer28
Dec 17, 2019 06:16 PM
Fatherof5
Jun 14, 2010 08:22 PM
Blazer91
Aug 11, 2008 07:07 AM
gscrippler
Jun 3, 2008 08:36 PM
Canadianblazer97
Jun 10, 2006 09:17 AM
