rough idle
Old Jun 29, 2010 | 08:19 PM
blazerpimping's Avatar
blazerpimping is on a distinguished road
Default rough idle
i have a 1995 chevy s10 blazer with the 4.3 v6. it has 2xx,xxx miles on it. my problem is that it has a rough idle. at first it was a constant almost dieing idle. we checked the sparked plugs and secured some more tightly and now it runs pretty smooth but when u press the throttle at all it goes into rough idle again for a few minutes then back to normal. what i need to know is what else could be causing it to do this?
Old Jun 29, 2010 | 10:09 PM
DKSDAD's Avatar
It could be the spider (fuel injector) dumping fuel, also check the EGR. They are known to foul up with carbon.
Old Jun 30, 2010 | 03:37 PM
6erwebb's Avatar
6erwebb is on a distinguished road
^^This. If it idles smooth but jumps around under load its either fuel or air (most likly fuel). Check the filters in the fuel system too with 200,000 miles they should have been replaced.
Old Jul 6, 2010 | 04:08 PM
Sisk's Avatar
** Moving to 2nd Gen Tech **
Please read all board descriptions before posting to make sure you're in the right place. The Lounge is for off topic/non blazer related talk. Thanks
Old Jul 6, 2010 | 08:31 PM
spacecowboy33w's Avatar
spacecowboy33w is on a distinguished road
Another possibility is the Fuel pump, you can check the pressure at the filter.
Also with that many miles the cat converter could be getting plugged up.
Old Jul 6, 2010 | 08:39 PM
Ryanmatt135's Avatar
Ryanmatt135 is an unknown quantity at this point
maybe a vacuum leak, throw a gauge oin it and see what your reading is
blazerguy22
Nov 14, 2013 11:50 PM
Chevrolet.Love
Aug 19, 2011 09:05 PM
nhguy261
Dec 30, 2010 01:41 PM
97BLAZE4X4
Feb 7, 2010 07:33 PM
c10jm
Aug 12, 2008 05:34 PM
