Rough running under load
Old Jun 13, 2009 | 08:35 AM
bstonian's Avatar
bstonian is on a distinguished road
Default Rough running under load
Recently I had the distributor mounting holes break on my 2000 Blazer 2 door 4wd engine code W. Consequently, I limped it to a garage to get it worked on. The mechanic there had difficulty installing the new distributor with out it throwing a code that said the distributor was in wrong. Finally he got it in right and now the engine starts and idles nice but when you drive it up the road a bad miss occurs. I believe its throwing a 1345 code. Would this be the cause of the bad miss under load??? I'm not sure my mechanic has the scan tool to do a case relearn if this is the case,,, ha,,, and would a case relearn solve this problem??? The engine ran beautiful before this. It had a new cap, rotor, wires, plugs, MAF sensor cleaned, etc.
Any help would be appreciated.
Old Jun 13, 2009 | 01:27 PM
P1345 - Crankshaft Position [CKP] Camshaft Position [CMP] Correlation
Take a read through that. This condition can sometimes be remedied by performing a CASE relearn (aka - Crankshaft Variation Learn or CKP/CMP Correlation relearn) which should be performed whenever the CMP or CKP sensors are replaced.
oopackmanoo
Sep 27, 2010 09:33 AM
slravenel
Feb 2, 2010 06:31 PM
chvy1
May 29, 2008 04:35 PM
Blue Blood
Jun 19, 2007 01:32 PM
doublek
18
Feb 1, 2007 10:58 PM
