rpm
Old Jan 21, 2011 | 11:03 PM
chevycrazy2011's Avatar
chevycrazy2011 is on a distinguished road
Default rpm
i have a 96 4 door 4x4 is 2500rpm normal for 60 mph?
Old Jan 22, 2011 | 12:19 AM
AJBert's Avatar
Depends.
What size tires and gears do you have?
Old Jan 22, 2011 | 12:23 AM
racsan's Avatar
racsan is on a distinguished road
like it was stated, depends on tire size/gear ratio, but that seems rather high to me, mine in overdrive at 55 mph is only about 1,600 rpm in 3rd its somewhere around 2,100 rpm thats with 3.42 gears and 235-70-15 tires. maybe youve lost overdrive?
Old Jan 22, 2011 | 09:59 AM
i have 235-75-15 i dont know the gear rotio what ever came in it stock the tranny was rebuilt at one time so i wouldn't think the od would be out but something to check out.
Old Jan 22, 2011 | 01:14 PM
blazinloud's Avatar
sounds high, torque converter not locking in?
Old Jan 22, 2011 | 04:11 PM
AJBert's Avatar
Sure sounds like it isn't even getting into 4th gear if everything is stock.
Old Jan 23, 2011 | 10:38 AM
hcii's Avatar
hcii is an unknown quantity at this point
You can check the torque converter by gently pressing the brake pedal - just enough to make the brake lights come on - and see if your rpm increases about 200 - 300 rpm. If it does, then the converter is locking up properly, and overdrive is working. The torque won't lock up if it's failed, obviously, nor will it work if the tranny isn't going into overdrive either.
mcaanda
Dec 15, 2009 08:31 PM
budiblazer
Jun 21, 2006 10:01 PM
Blazer96
Mar 18, 2006 02:09 AM
burcham
Nov 22, 2005 05:21 PM
2001Blazer4x4
Apr 20, 2005 12:09 AM
