RPM'S
Old Feb 9, 2009 | 12:43 PM
Numba1Sean's Avatar
Numba1Sean is an unknown quantity at this point
Default RPM'S
Just wondering what the rpm's should be in reverse and drive. mine i thought was to low at 500 rpm, sometimes reverse could be slightly lower.
Old Feb 9, 2009 | 12:48 PM
Default RE: RPM'S
You are quoting idle RPM when in reverse gear and in drive gear? They both should be quite similar, but so long as they are between 500-600 RPM with a fully warmed up engine/transmission, you should be fine. Is it wanting to stall out on you? Have you ever cleaned your throttle body?
Old Feb 9, 2009 | 09:18 PM
Numba1Sean's Avatar
Default RE: RPM'S
no i havent cleaned that or the iac or the egr, waiting for a warmer day. but the rpm's do what they want, sometimes they will be ok sometimes they will be lower then ok. and yes in gear at idle with foot on brake no system lol. oh and i dont get anymore anymore flickering headlights with the newad244 alternator, so far so goodon this alternator. but yea the only reason i ask about the idle rpm's is cuz they are never the same, always changes. add this too sometimes when shifting into drive the rpms will go higher stay there for a second or two then go to the regular 500 rpm's
Old Feb 10, 2009 | 07:15 AM
Default RE: RPM'S
I would clean the throttle body real well and see how things work after that.
Old Feb 10, 2009 | 11:16 AM
Numba1Sean's Avatar
Default RE: RPM'S
ok should i take it off and clean it or just spray in there and toothbrush it real good?
Old Feb 10, 2009 | 11:58 AM
Default RE: RPMS
I prefer to remove the TB to make sure that you do not inadvertently drop something down into the intake.
Old Feb 10, 2009 | 12:42 PM
Numba1Sean's Avatar
Default RE: RPMS
ok thanx man me and my buddy are gonna take care of that and the egr tommorow. thanx again.
Old Feb 11, 2009 | 04:46 PM
Numba1Sean's Avatar
Default RE: RPMS
ok throttle body cleaned (real dirty) better response now. egr valve was barely dirty cleaned also. still getting rpm fluctuation
mcaanda
Dec 15, 2009 08:31 PM
budiblazer
Jun 21, 2006 10:01 PM
Blazer96
Mar 18, 2006 02:09 AM
burcham
Nov 22, 2005 05:21 PM
2001Blazer4x4
Apr 20, 2005 12:09 AM
