RPMs fluctuating
Old Apr 6, 2014 | 06:36 PM
TheSheepDog's Avatar
TheSheepDog is on a distinguished road
Default RPMs fluctuating
Hey guys and gals. So I'm not exactly having great luck with my '01 Blazer. I recently fixed her up and got most of the issues gone, after I installed a new muffler I noticed my RPMs were dropping about 100 or so while cruising. I checked my fluid, it's clean and at the correct level. I decided to bring the rpms up to around 1500 in park and it did the same thing so I ruled out torque converter, also fluctuated at idle. Then I realized the defroster was on and when I shut that off, all was good. Also I had noticed before that when the defrost was on, my ac compressor clutch was kicking on and off constantly.
I haven't taken it down the road yet, but it seems to have something to do with the A/C clutch and defrost. Any ideas here?
Edit: I may just be an idiot. I worked HVAC for a short time and now that I think of it it's probably low on refrigerant since it's kicking on and off every 10 seconds or so. I'll have to check my lines for a leak. The clutch is pretty noisy though, bearing maybe?
Old Apr 6, 2014 | 07:07 PM
newguy's Avatar
I believe the ac does kick on in defrost mode
Old Apr 6, 2014 | 07:11 PM
Yeah it does, hence why I said I was an idiot haha. The AC kicks on to dehumidify the hot air being brought in by the defroster. Since mine is kicking on and off so often, I'm thinking it has a leak in the lines and is low on refrigerant. My only concern now is the noise the clutch produces
Old Apr 7, 2014 | 12:54 AM
joejiz's Avatar
joejiz is on a distinguished road
I believe in the manual for truck it says when driving when the ac kicks on truck doesn't accelerate as fast. and this is be design. side note
DannyD
Sep 30, 2010 07:57 AM
kwoodkayaker
Engine & Internal
14
May 7, 2010 03:05 PM
sorensic42
Jan 18, 2007 12:06 PM
ssilk12001
Sep 14, 2006 01:16 AM
dashyman
Aug 29, 2006 01:05 AM
