running not so great
Old 08-24-2011, 01:07 PM
drewsblazer's Avatar
drewsblazer is on a distinguished road
Default running not so great
i drive a 95 blazer 4.3 with 170k and it recently started doing this, under acceleration ill hear some popping from the exhaust and some slight hesitation plus my tachometer will go crazy i.e. will fluctuate from where my rpms should be to 1k over where it should be. any help or hints would be great
Old 08-24-2011, 01:10 PM
xgiovannix12's Avatar
got an ses light on?
Old 08-24-2011, 01:19 PM
no check engine. also just replaced all 6 spark plugs last month
Old 08-24-2011, 01:28 PM
what did you replace them with ?
Old 08-24-2011, 01:29 PM
pettyfog's Avatar
Check your distributor cap and rotor. Check your plug wires with it running in the dark
Have you done anything else to it recently.. or had any other incidents? Trouble starting after rain during night, etc...
Did it start very minor and getting worse?
Old 08-24-2011, 01:55 PM
i got ac delco plugs after i was getting a misfire code from the ecu and yes it progressively got worse
Old 08-24-2011, 02:27 PM
I think a decent tune up will work
Id change cap rotor wires id use ac delco for cap and rotor ac delco wires are good also
I mean it dont hurt to change them
Old 08-24-2011, 08:08 PM
okay so i replaced the cap and rotor with ac delco parts and still no luck. still running rough, i also replaced the fuel filter cause i was bored. still running like crap... should i be checking injectors now?
Old 08-24-2011, 08:10 PM
i say go with a fuel pressure test
Check this artical out
https://blazerforum.com/forum/tech-a...agnosis-23038/
Old 08-24-2011, 08:15 PM
mines a 95. any difference?
Quick Reply: running not so great
