running rich
Old Dec 28, 2006 | 12:59 AM
jdblazer's Avatar
jdblazer is an unknown quantity at this point
Default running rich
ok i still have a random misfire but i have learned that if it sits for about two days it will start right up like the gas has to evaporate if i try to start it the next day it takes for ever to start i can also smell gas a little outside of it and the exhaust is wet especially when first started any ideas will be appriciated.
Old Dec 28, 2006 | 01:29 AM
20Blazer00's Avatar
Default RE: running rich
Sounds like a fuel leak in the upper intake. Fuel pressure regulator, spider fuel distribution block, poppet valve stuck open or leaking fuel line...depending on the model year will depend on what parts are involved...
Old Dec 28, 2006 | 03:28 AM
Chevy Lover's Avatar
The best way to test for an internal fuel leak is to use a fuel pump pressure tester. Run the engine with the tester installed, then shut off the engine and watch the guage. It should hold residual pressure. If it drops to a very low pressure in a short period of time, it has an internal leak.
ksimpson
14
Oct 7, 2013 05:25 AM
Vince's04blazer
Jan 11, 2010 05:45 PM
uncledenny
Jan 8, 2010 04:09 PM
dbinnc
Sep 28, 2008 03:17 PM
Smoked
Apr 8, 2008 07:43 AM
