Scary oil drip!
Old May 24, 2024 | 06:08 AM
mugenmundo's Avatar
mugenmundo is on a distinguished road
Default Scary oil drip!
Ok so I'm getting ready to replace remote oil lines along with oil cooling lines. As I sat underneath the truck, I noticed this new drip. Its between the Bell housing and Engine block. It seems to be mostly coming from passenger side and possibly inside bell housing. Keep in mind, I just degreased & power-washed the entire under-frame. I have not driven the truck anywhere and this drip appeared after sitting for 3 days on ramps. I took pictures of the Drip and also the driver side and passenger side.
Old Jun 3, 2024 | 05:05 AM
Give it another wash, or wipe with brake cleaner.
I've seen residual oil drip like this once it warms up after a thorough wash.
The Blazers is not notorious for oil leaks, other than from fittings.
May want to check out from bottom to top and have a look at all the fittings into the block, cylinder heads and especially valve covers.
Old Jun 3, 2024 | 07:44 AM
mugenmundo's Avatar
OK will clean with brake cleaner and report back.
DarrinS91
May 30, 2021 12:35 PM
Zelta
Jan 26, 2021 02:35 AM
cahlersmeyer
23
Nov 10, 2011 09:23 PM
Taymacjack
Apr 4, 2008 08:59 AM
rastaskater
Jan 29, 2008 08:32 AM
