Screaming Front End
Old Mar 14, 2010 | 06:22 AM
cjh's Avatar
cjh
cjh is an unknown quantity at this point
Default Screaming Front End
Ok...I had a previous post concerning my 96 jimmy 4x4.
There were no replies..that's cool..it was a techy question.
So...the front pass side cv is screaming behind the area where the two flanges with the 6 or 8 bolts clamp the crap together.
The shaft can be raised up approx 1-1/2'' just outside the tranny case or whatever you want to call it.
(frame is on jack stands,which would add play cause shaft is hanging)
Question...Is this thing repairable (I'm thinking about a destroyed bushing inside the case)
Am I out of line in my thinking,I plan on yanking the CV shaft and checking it out.
Is the INNR bearing replaceable witout dropping the tranny.
If not..she's gonna get scrapped.
Old Mar 14, 2010 | 09:10 AM
Sadchevy's Avatar
Sadchevy is on a distinguished road
its actually your differential ......and it sounds like the outer bearing is gone. yes its repairable.
Old Mar 14, 2010 | 01:20 PM
jhood17's Avatar
jhood17 is on a distinguished road
Default same issue
I have the same issue with my blazer 98.. its comming from the passenger side and my tech said it was the bearing inside the axle it cost me 15 bucks in parts to fix from a dealer. he pulled out the axle and used a long bar to bang out the old bearing threw the old one in and then reinstalled.... havent picked it up as i need to replace the pitman arm and a couple other things...
doktornasty
Nov 3, 2013 03:12 AM
BLAZER97LS
Apr 16, 2012 02:56 PM
brino1
Feb 25, 2011 08:05 PM
ComputerNerdBD
Mar 18, 2009 06:13 PM
Blenton
Dec 18, 2007 11:52 AM
