Screwed up somewhere installing new fuel pump :(
Old Nov 12, 2013 | 01:30 PM
newguy's Avatar
Can you disconnect the fuel line from the top of the fpr and check the flow
Old Nov 12, 2013 | 01:50 PM
spittybays
Guest
Posts: n/a
Originally Posted by 07nhbpsi
Hard to tell at this point u really need to get a fuel pressure tester!!! Really u know its getting fuel but..... How much is the question? Did u try starting fluid? Before u started pulling it apart?
That little port on the back with the pin is your test port. PSI is correct. Without testing the actual pressure at this point you are chasing your tail.
You can borrow one at autozone with deposit.
Old Nov 12, 2013 | 03:30 PM
Topspeed02's Avatar
Topspeed02 is on a distinguished road
Fuel pressure is good! If I take the intake cover off and plug the injector plug back in.... If I turn the key I should get fuel through the nozzle right?
Old Nov 12, 2013 | 03:58 PM
spittybays
Guest
Posts: n/a
Only way to tell if fuel pressure is good is to put a gauge on it. 50 psi will spray fuel everywhere but will not start your truck. Please read this.
https://blazerforum.com/forum/tech-a...agnosis-23038/
BouncingRadical
14
Nov 27, 2015 12:30 AM
bam_9_9_9
Jun 28, 2014 12:57 PM
Zach_Michaels
Aug 17, 2011 10:58 AM
rabbit0102030
Shows & Clubs
19
Apr 15, 2008 09:30 AM
FoxTrota
Apr 10, 2008 11:58 PM
