Second air error on scan tool
Old Jan 20, 2015 | 05:19 PM
You'll need a scanner that is capable of graphing the oxygen sensors individually to spot a problem. The monitor relies heavily on oxygen sensor data. Oxygen sensors react to changes in fuel mixture. Reaction time from lean to rich, and rich to lean can vary, even on brand new sensors. The faster they react to changes, the faster the PCM can correct the mixture to achieve the best possible fuel mileage. As they age, thier reaction time slows down, (normal). When it gets too slow in one or both directions, the PCM sets a DTC in memory. The "failure" point is programmed into the PCM software, and can vary between model years. If one or both upstream oxygen sensors are close to the "failure" point, it might affect the secondary air monitor.
Old Jan 26, 2015 | 07:58 PM
air1force1's Avatar
air1force1 is on a distinguished road
Update. The temp was only maxing out at 150. Changed the thermostat tonight. Now to drive it some more.
Old Jan 28, 2015 | 02:35 PM
air1force1's Avatar
Update: another monitor set to "ok" (EGR). Now i just need second air, or catalyst mon. to pass insp. I understand it may take 5 drive cycles to get the catalyst. Keep driving.
Thor_449
Apr 21, 2011 09:23 AM
Mikeinnh
Apr 20, 2011 06:21 AM
jnail
Oct 15, 2009 03:06 PM
gmaltese
Aug 16, 2009 08:07 PM
