security
Old May 22, 2010 | 06:01 PM
bhalb's Avatar
bhalb is an unknown quantity at this point
Default security
I don`t know if this has been addressed before but ,
my wifes 99 Blazer 4dr 4wd LT won`t start. Ran fine yesterday. The security light on the dash now stays on. I assume something tripped it. Is there a way to reset this?
Old May 22, 2010 | 09:38 PM
R134A's Avatar
R134A is on a distinguished road
Try to disconnect the battery for a few minutes and see what happens.
Don't know if you got this try to disconnect your battery for a few minutes.
Last edited by swartlkk; May 23, 2010 at 12:48 PM. Reason: **Combining Consective Posts** - Please use the EDIT feature to add information to your post if another member has yet to reply.
Old May 22, 2010 | 11:06 PM
wlorton's Avatar
What you do is you sit with the key in the on position for about 15 minutes I think.... and then the security passlock system will be reset....
Old May 23, 2010 | 01:21 AM
tlawre87's Avatar
tlawre87 is an unknown quantity at this point
^^^def try resetting the passlock system
Old May 23, 2010 | 07:11 AM
bhalb's Avatar
Thanks guys, I`ll try these. Sure hate to have it towed to the dealer
Old May 23, 2010 | 08:50 AM
vetteandblazerman's Avatar
vetteandblazerman has a little shameless behavior in the past
Try this, it worked for me and a few others. Remove the batteries from your remote keyfob,
then press the open and close buttons together for a few seconds. This has the effect of
clearing any memory in the fob, then replace the bats and try! Good luck i know the feeling
you have.
Old May 23, 2010 | 12:49 PM
The fob has no memory...
PASSLOCK - Reprogramming Auto Learn
Old May 23, 2010 | 01:25 PM
Ok, so the fob has no memory, but this trick worked for me and others on YOUR forum.
I was just trying to help the man.
Old May 23, 2010 | 01:54 PM
Tone the attitude down man. I was merely stating facts.
Old May 23, 2010 | 04:13 PM
bhalb's Avatar
Thanks for all the replies. Tried the key in the on position for 15-20 minutes. That seemed to do the trick. It started right up. Thanks again for the replies.
sbranch
Jun 2, 2006 04:29 PM
lovetheblazer
Mar 27, 2006 11:16 AM
2klt
Feb 27, 2006 11:15 PM
Canadian88
Feb 25, 2006 02:27 PM
gstclair83
Feb 13, 2006 03:53 PM
