security issue i think..help
Old Aug 22, 2012 | 02:59 PM
warthogdriver's Avatar
Default security issue i think..help
ok,
so yesterday i tore down the dash to do the heater core.
i disconnected the battery then went on my way towards taking out the dash.
everything came apart smoothly.
so today i go out this morn to finish the job...all goes well.
no connections missed no left over parts. went back together fine.
now however it wont start. the security light is on all the time.
so i figure maybe do a relearn (as in the help section here)...no dice.
i waited for ten minutes and even longer...that light is still on.
when i turn the key back to on the securtiy light goes off for maybe a second or two..then its back.
Key fob works though.
i dont know what i did. i did disconnect the bcm to move it out of the way when pulling the dash. i also put it into first to drop the lever for some more clear space.
also i dont know if this is related to the security or not but the gear indicator lights up but will not show what gear it is in (park at the moment)
before i did the work i never had any issues at all with the passlock system...always started immediately.
i simply dont know where to look at this point. i tore the dash back apart looking for something i missed....nothing was out of place. no pinched wires or anything.
oh i also tried hooking up my obdii scanner and it says it cant talk to the ecu.
i am outta ideas....i have been at this all day and i am about to have a melt down.
Old Aug 22, 2012 | 03:14 PM
50lb_cat's Avatar
Might have to take it to the stealership, definetly sounds passlocl related. When I replaced my ignition switch, (followed the how to here) I had the same issue. I did the relearn and nothin, my buddy at the dealer hooked it up to there computer and did the relearn and it was fine.
Old Aug 22, 2012 | 03:28 PM
I am sure that can be done for a nice amount.
edit.....100.00 at my local stealership....nice
Also...what causes this to happen?
I have had my blazer apart tons of times with the battery out far longer....i just dont understand how the system works.
Old Aug 22, 2012 | 07:10 PM
50lb_cat's Avatar
My buddy at the dealership didn't have an answer either. So I cany help you with why or how it happened. Sorry! When I had my pcm tuned, I had them tune out the passlock crap.
All it cost me for him to do the relearn was a 12 pack lol.
Old Aug 22, 2012 | 07:32 PM
yeah....75.00 more and i could had a tune instead.
i figure that the dealership loves easy money...as soon as i told them what was going on they said bring her in.
best part was when they asked me if i had been there before i proudly said.."i dont ever go to shops" i take pride in fixing my busted up old junk.
Old Aug 22, 2012 | 07:51 PM
Thogert's Avatar
Want to come fix my busted up old junk?
Old Aug 22, 2012 | 08:10 PM
Tell ya what...you fly me out there and i will do my best
Old Aug 24, 2012 | 10:06 AM
El_Beautor's Avatar
It's definitely passlock related. I'd almost wonder if the BCM is not seeing the resistance code from the ignition switch. Is it possible that you either pinched a passlock wire coming from the steering column, or missed reconnecting something?
Do you have an aftermarket alarm or remote starter? If you have a remote starter, did the passlock bypass module miss getting plugged back in?
Old Aug 27, 2012 | 08:16 PM
^^^...well let me tell ya.
ok finally got it to dealership over the weekend and i got a phone call from them today.
well its not the security system at all...apparently i screwed up the wiring. so tomorrow i am towing it back home and it will have to sit till this weekend so i can take the dash back out. i hate when i find out i screw up something like this...esp when someone else finds it.
i am not having a good year with elec issues and cars. they said i probably screwed up a ground in the dash by pinching a wire or not fully seating the connection.
on a plus note...they tested my electronics and they all check out...so wire hunting i go.
d'ohhhhhhh
lousy is all i can say.
Old Aug 28, 2012 | 07:48 PM
ok,
well i had five hours to kill today...schedule opened up for me
and all is now well in my little corner of the blazer world.
i tore the whole thing back down and found the wire problem...patched...crossed fingers and she worked!!!
its the little things that get you....i have had that dash apart so many times and i guess the last one was one time to many.
Tony H
Sep 14, 2012 12:22 AM
vlb6472
Jan 19, 2012 06:18 PM
Chris99
Sep 28, 2011 03:52 PM
butters
Feb 7, 2009 10:59 AM
red/white04
Jan 28, 2009 08:03 AM
