Security System Disable
Old Mar 24, 2009 | 09:19 PM
jcortes63's Avatar
jcortes63 is an unknown quantity at this point
Default Security System Disable
Please I have been reading a lot about this security system., seems to be there is no way to turn it off., it is the PLJX feature a solution even if I don't want to use a remote starter, even if I have to put a manual switch under the dash board or where ever it will work for me..., Please any help.
regards
jcortes.
Chevy Blazer LT 2000.
Old Mar 24, 2009 | 10:05 PM
rriddle3's Avatar
Exactly what security system are you talking about?
Old Mar 24, 2009 | 10:17 PM
jcortes63's Avatar
The anti theef ., that stops the fuel pump.., I've been driving my blazer at night and suddenly stops.., after a while it start working ., while in the middle the security light was flashing till it gets permanent I can not turn on the car., I already have done the programming process...
1. crank just one second//
2. move to on. keeps ten minutes.
3. go to off ...
repeat three times... it works for some days.., the fuel pump is new so I don't think that is the problem.., it is something related to the ignition and pumping fuel.
regards..
jc
Old Mar 24, 2009 | 10:26 PM
rriddle3's Avatar
This sounds suspiciously like a problem with the ignition switch.
Old Mar 25, 2009 | 07:50 AM
Just change out the faulty ignition switch and your problem will go away, no security defeat needed.
Tony H
Sep 14, 2012 12:22 AM
greatwhite
Jul 12, 2011 10:50 AM
knight1292
Aug 14, 2008 09:30 AM
tycobb280
Sep 28, 2006 12:21 AM
Canadian88
Feb 25, 2006 02:27 PM
