Service 4wd warning
Service 4wd warning
On my way home from work tonight I inadvertently hit the four hi button while adjusting the air vent that is next to the 4x4 control buttons. The service 4wd light came on.I pulled over and tried to put in back in 2 hi. I heard the usual click from underneath the dash. The clicking kept repeating until it went back into 4 hi. I was able to get it to stay in auto 4wd for awhile, but eventually all of the indicator lights on the buttons went out and wouldn't come back on and the service 4wd remained lit.
Obviously I'm going to take it to get it checked out, but I thought someone here might know something that I could do that I wasn't aware of. Also, assuming it's in auto 4wd, is it okay to drive? I drive quite a bit and need to at least drive tomorrow.
Thanks!!
Thanks!!
RE: Service 4wd warning
If you remove the 4WD fuse and reinstall it, it should reset to 2HI. Beyond that, the Auto4wd transfer case control system is quite complex in its operation which makes it very difficult to trouble shoot with out the proper diagnostic tools.
ORIGINAL: swartlkk
Drive it a bit in tight circles to see if you get any binding in the drivetrain. If you do not notice any, then you should be good to drive it. If you do notice binding, you can disconnect the vacuum line to the front axle vacuum solenoid on the firewall which will disengage the front axle.
ORIGINAL: swartlkk
Should be close to the center. It will have an electrical connection and two vacuum lines.
ORIGINAL: swartlkk
So long as you remember where they came from and plug them with something (golf tees work great for this), you should be good. You probably could disconnect the electrical connection as well and done the same thing.
ORIGINAL: swartlkk
In 2HI, the vacuum pressure is released at the transfer case. But he is having trouble getting it back into 2HI.
parks336
12-01-2023 12:34 PM
rgkkw1221
08-05-2014 06:23 PM
Geir
10-09-2011 08:51 PM
ESKYMOPACK
06-20-2009 07:16 PM
