service engine light wont come on, but theres codes
Old Jul 31, 2015 | 12:03 PM
LesMyer's Avatar
Originally Posted by er0ck273
Just looked at the screenshot I took of the scannet....upper right hand corner "pending".... So if a code is pending the light won't show at all?
If you read the description in the tech articles for P0340, it say it has to be a problem on 2 consecutive key cycles before the SES light will come on. I assume the code you are reading is pending from problem on only 1 key cycle or on non-adjacent key cycles.
I noticed similar behavior with a pending misfire code on mine at one point in the past.
If you are getting a pending PO340 after clearing (but no SES light at the moment), then you most likely still have an intermittent problem that on occasion might decide to turn on the SES light.
Old Jul 31, 2015 | 02:55 PM
er0ck273's Avatar
er0ck273 is on a distinguished road
im gonna recheck and see if theres any current codes. yea the time after the whole engine turning off while driving, it ran fine.
is there a way to check if the ses light it functioning properly? it does come on when key on engine off
Old Aug 3, 2015 | 03:34 PM
LesMyer's Avatar
That and the light going out when started is the check.
Cheers
Les
Old Aug 3, 2015 | 04:03 PM
er0ck273's Avatar
Cheers
Les
i should be all good to go then. thank you!!
Old Aug 3, 2015 | 04:44 PM
P0340 is a type "B" DTC. This link explains: OBDII - Diagnostic Trouble Codes - Types of DTC
Old Aug 3, 2015 | 06:35 PM
er0ck273's Avatar
just when i thought a code was just a code...there different types haha. definitely good info captain, thank you!
SouthSide Tay
Tires and Wheels
Apr 10, 2014 08:06 PM
2003_CHEVY_BLAZER
Dec 21, 2011 07:16 AM
damageinc98
Jul 12, 2010 10:47 PM
kmartin
Sep 23, 2009 04:37 PM
gmyoyo
Engine & Internal
Mar 29, 2005 12:17 PM
