service engine soon lite
Old Aug 10, 2009 | 02:57 PM
Tony H's Avatar
Tony H is an unknown quantity at this point
Originally Posted by swartlkk
Just gotta look in the right place. It could also be called the purge valve. The FSM calls it the vent solenoid. Parts manufacturers call it whatever they please...
ACDELCO Part # 214633 is the proper part. Be aware that the hose connection may be different. All of the documentation states that a new hose will be needed, but in all of them that I have replaced (6 that I can remember), it has never needed a new hose.
Thanks, That Delco Site I gave ( above) had that part and I clicked on it but there was no picture for it so I had no way to confirm.
Thanks
Old Aug 10, 2009 | 03:02 PM
RockAuto.com as well as ACDelco.com have pictures.
Old Aug 10, 2009 | 03:10 PM
Tony H's Avatar
Now that I know what part number and Description.. I can find it. Here's somethinmg I stumbled on. I wonder if ours can be cleaned to keep the Solenoid from hanging up and giving us a Code. The pictures will probably tell me whether this one can be cleaned.
http://www.s-10crewcab.com/phpBB2/viewtopic.php?t=6108
I'll check Rock Auto
Old Aug 11, 2009 | 07:38 AM
Tony H's Avatar
I know and I apoligize for beating this to death but The more I look up Parts the more I have questions as to where the Small Evapo Leak is coming from PO440. The Item by teh spare tire is a Canister Vent Valve but there is a Canister Vent Solenoid up on the Intake manifold. Looking at what they are doing at http://www.s-10crewcab.com/phpBB2/viewtopic.php?t=6108 it looks like this Valve gets dirty and causes the solenoid at the intake manifold to hang open . Is that what is happening with our S10's. Even if I replace the Valve at the Rear tire, the solenoid at the Intake might be dirty enough not to close.... it's that a true statement?
Old Feb 22, 2010 | 02:51 PM
Tony H's Avatar
Default Vent Solenoid..Purge solenoid
Get the code and go from there.
The evap canister is located behind the driver rear tire. Purge solenoid is located on the engine in front of the ICM. Vent solenoid is on the cross member just forward of the spare.
If replacing the gas cap did not cure the problem, then your problem is likely the vent solenoid, but check over all of the EVAP lines first to make sure there is nothing cut or broken.
NAPA only shows a Vent solenoid for my '99 but they call it the Purge solenoid.
Is there a rubber 'o' ring in the hose that attaches to the Purge solenoid that keeps it from leaking when the hose is snapped in? My little plastic snap ring on the hose is broken, will that cause a Code? PO440 I think I have
Old Feb 22, 2010 | 05:55 PM
piedmontfbody's Avatar
piedmontfbody is an unknown quantity at this point
Default gas cap code- new cap didn't fix
I have had the same problem since December. Bought a new cap and disconnected the battery to clear the code. After the 3rd start, the light came on again. Same code. Every once and awile, i will hear a high pitch whistling coming from the rear of the vehicle.
2000 4dr, 4x4. 100k
What is the most likely culprit of these 3 sensors?
Thanks
Old Feb 22, 2010 | 06:19 PM
The most likely cause is the vent solenoid under the back of the truck. But to get further into it than that, you really should create a new post on your problem seeing as how the author of this thread still has not remedied his problem.
Old Feb 23, 2010 | 07:34 AM
Tony H's Avatar
2000 4dr, 4x4. 100k
Thanks
Follow me here.. I may have answered the order of thing s to look at. Vent solenoid seems to be the main culprit. not for me though
https://blazerforum.com/forum/showth...945#post303945
Old Feb 23, 2010 | 07:52 AM
This post runs down through the usual things to look at as well..
Old Feb 26, 2010 | 08:51 PM
Thanks guys. I'll let you know what I find.
