SES light back on
#21
Torque Pro is a smart phone app that is used in conjunction with a bluetooth enabled scan tool. I use Torque Pro on my phone with a Scantool.net OBDLink MX OBD2 adapter.
I also have Autoenginuity's Proline connector for more involved jobs and have yet to find a diagnostic chart that I cannot perform all of the steps on, including setting the CMP Retard and running through the CKP Relearn on my friend's '01 Bravada. It can access all of the serial bus connected systems (ABS, TCCM, SRS, etc).
I have used a few different PC based scan tools and so far, the Autoenginuity tool has been the most "bang for your buck" tool I have used. I will be selling it soon to upgrade to EFI Live's Scan & Tune setup. About twice the money as Autoenginuity, but gives me the ability to make changes to the tune on both my Denali and our Duramax work truck.
My $150 software is ScanXLPro with GM Enhanced package. I was able to use it in terminal mode to talk to my 4WD TCCM and to display camshaft retard. I thinkit does some ABS and other things as well but have not investigated. My $300 software is the HP Tuner's VCM Scanner only (without the capability for changing tune). It has the capability to do things like injector balance test, crank sensor relearn, and can control transmission, torque converter clutch, and a variety of other things. Of course there seems to be a lot of additional functionality that I have not yet investigated.
I have heard good things about the EFI Live, but no experience with it.
Didn't realize that Tuna was asking about the same hand held scanner that you have. If I remember correctly, your scanner was a handheld that did do a lot. Can't remember if you said it would trip crank relearn procedure but I'm quite sure it could display camshaft retard.
Les
#22
Yikes! I think all this may be above my pay grade.You sure have provided some "food for thought". I'll have to chew on this a bit. The only other thing I can say at the moment is:
My SES light came back on yesterday while climbing a steep grade at about 45 mph, in the rain. So I'm now convinced it is not the fuel blend. Hence, the need for a good scan tool.
Thanks gentlemen!
Thanks gentlemen!
#23
Thanks gentlemen!
Thanks gentlemen!
#24
Thanks gentlemen!
Thanks gentlemen!
![Icon Wheel](https://blazerforum.com/forum/images/smilies/icon_wheel.gif)
zedartwo
02-04-2010 02:30 PM
