SES light with heavy throttle
Old May 30, 2012 | 04:40 AM
vortec bowtie's Avatar
vortec bowtie is on a distinguished road
Yeah I found some online for like 50 bucks. I think I'll just do that.thanks for the help
Old May 30, 2012 | 09:50 AM
50lb_cat's Avatar
Post back if that doesn't help, but I bet that's your problem.
Old May 31, 2012 | 06:41 PM
When I get my new one on should i have it welded or clamped? How much would a muffler shop charge to weld it? Cause I wouldnt trust anyone in my schools welding shop to do it
Old May 31, 2012 | 07:05 PM
50lb_cat's Avatar
Definetly welded. Call around to different muffler shops I'm sure they won't charge much to weld it on.
Old May 31, 2012 | 07:22 PM
Might want to check exhaust backpressure, rather than spend money on a guess.
Old Jun 1, 2012 | 09:30 PM
How could I go about checking it? check pressure before and after cat?
Old Jun 1, 2012 | 10:12 PM
You'll need a vacuum/pressure gauge, Fuel Pump and Vacuum Tester You'll also need an old oxygen sensor or spark plug to make the adapter.
Check backpressure at one of the upstream oxygen sensors and also at the downstream oxygen sensor, (after the converter). Should be ~1psi in both tests at 2,000 RPM. This video does a fair job at explaining it:
Exhaust backpressure testing - YouTube
levi1a
Sep 24, 2011 07:27 PM
93blazerman
May 5, 2006 03:36 PM
blazinloud
Engine & Internal
May 1, 2006 02:53 AM
bongabilla
Mar 16, 2006 09:36 PM
awalls
Feb 14, 2006 03:28 AM
