SES and temp
Old Oct 20, 2008 | 09:27 AM
mattd's Avatar
mattd is an unknown quantity at this point
Default SES and temp
2002 Blazer LS 2WD 4D 65k miles
Had the service engine soon light come on. The only thing I can notice is that the temp is registering low. It is reading 150-160. Any ideas? Heat is blowing just fine. Fluids seem ok and nothing looks disconnected (at least that I can see).
Old Oct 20, 2008 | 10:08 AM
Default RE: SES and temp
Sounds like a bad thermostat to me. You should verify that the temp is actually low as well as get the code read. A thermostat can stick open, reducing the system temperature and not drastically affect the heater output inside the vehicle.
Old Oct 20, 2008 | 11:50 AM
mattd's Avatar
Thanks for the info. Took it to the shop this morning, so I will post the outcome.
I had someone else tell me it may be the thermostat, and then another person told me that if it were the thermostat it would be running hot, so it is probably an 02 sensor. Should hopefully know soon.
Old Oct 20, 2008 | 12:22 PM
Most thermostats are fail-safe now. Which means, if they fail, they fail in the open position.
Old Oct 20, 2008 | 01:41 PM
mattd's Avatar
So does that mean that if it fails in the open position, it could possibly cause the low temp.?
Old Oct 20, 2008 | 02:41 PM
mattd's Avatar
Got it back from the shop. Here is the write up:
"Check engine light on, ran diagnostic test, (extended time to reach operating temperature) drain coolant, replace thermostat and seal, refill coolant, purge air from system, clear computer, retest operation."
$108.87 TT OTD
Vehicle heats up just fine now.
Not too bad...
Old Oct 20, 2008 | 02:45 PM
Thought it would be about that. Sad part is, the thermostat costs around $15 for a good one and coolant would be around $10...
builder125
May 20, 2013 06:51 PM
zakm0n
Jan 9, 2011 07:31 PM
MellowedZR2
Jul 22, 2009 10:07 AM
DaddyCop03
May 11, 2008 09:07 PM
naf821
Aug 8, 2007 07:19 AM
