Shaking/vibrating from rear
Old Feb 4, 2009 | 02:51 AM
troyky29's Avatar
troyky29 is an unknown quantity at this point
Default Shaking/vibrating from rear
I have a 97 Blazer 4x4 4.3. I have a shaking/vibrating coming from the rear. It usually does when going around 55-60mph and going up any hill. It will do fine in lowerspeeds and usually on flat roads. When it starts, I can let off the gas and it will quit. Transmission shifts smooth. Thought it was only doing it in overdrive so I put it in 3rd gear and tried it. Still done it. It is very loud and can be felt easily. I havent checked anything out yet, just thought I would get some opinions first. Any suggestions would be a great help.
Old Feb 4, 2009 | 06:49 PM
getonerd's Avatar
getonerd is an unknown quantity at this point
Default RE: Shaking/vibrating from rear
yea me 2 but i got a 02 blazer
Old Feb 6, 2009 | 02:50 PM
troyky29's Avatar
If you find out what the problem is with yours, let me know. Or if anyone else has any ideas, I would like to hear them. Mine is used as a spare, so it is not driven much anymore.
Old Feb 7, 2009 | 01:57 AM
blknwhtblaze's Avatar
blknwhtblaze is an unknown quantity at this point
Have you checked your U-joints mine used to shake when you are on the gas but as soon as you let off then it didn't shake so give that a try
Old Feb 8, 2009 | 03:36 PM
troyky29's Avatar
I checked out the u joints. There is no play at all in the driveshaft. Started to check some stuff and noticed if if you shake the rear passenger side tire you get a popping noise. It also seems like it has some play in it. Does this sound like a bearing?
thibault116
Mar 16, 2013 10:40 PM
jake2011
Aug 19, 2011 12:53 AM
BBurton321
May 4, 2011 11:23 PM
elementalnature
Jul 9, 2008 06:47 PM
Dturner14
Jun 30, 2007 11:32 PM
