Shift Linkage Bolt
Old Jan 25, 2012 | 02:49 PM
WesX's Avatar
WesX is on a distinguished road
Default Shift Linkage Bolt
Not really sure if I'm using the correct terminology here but the nut on the end of the shift linkage arm came off and I wanted to know if I can just get a new nut or do I have to replace the whole arm?
This is from a automatic 4x4 '98 Chevy Blazer.
Old Jan 25, 2012 | 03:10 PM
spittybays
Guest
Posts: n/a
That looks like it might be some kind of clip. Is that stud rivited? You might get it out with an angle grinder then nut and bolt it or clean it up real good and maybe it will snap back in with a C clip on the back.
Old Jan 25, 2012 | 05:31 PM
atvwarrior's Avatar
atvwarrior will become famous soon enough
I think the way its designed you have to get the whole arm , but I'm sure you could take it off and put a bolt with a spacer / washer / and nut on it and make it work .
Old Jan 25, 2012 | 05:50 PM
chris015's Avatar
Yea...that things dead. Take off the bracket and drill that out. then stick in a bolt and put that linkage back on and throw a locknut on it. Fixed.
Old Jan 27, 2012 | 12:37 AM
WesX's Avatar
That was my original plan. Haven't really tried to take off the arm yet but any idea how hard it is to get it off? Do I just ratchet the bolt that holds the arm on? I know moving the arm back and forth changes the gears.
Thanks for all the help!
Old Jan 27, 2012 | 07:01 AM
spittybays
Guest
Posts: n/a
I guess your not using it right now so hit it with PB blast for a couple of days also when you do put a wrench on it try jam a screw driver some place to stop the arm from moving. I worry that the pressure your going to have to apply might break something expensive inside. If it feels like somethings about to break see if you can do it some other way, with it still attached. Maybe cut the stud of with angle grinder and drill it out in place.
warthogdriver
Oct 22, 2009 04:37 AM
chris015
Apr 28, 2009 09:36 AM
newgem
Mar 2, 2009 09:30 AM
mattdunning
Dec 30, 2008 07:31 PM
Bonovox
Sep 5, 2007 06:25 PM
