Shift Linkage Bolt
Not really sure if I'm using the correct terminology here but the nut on the end of the shift linkage arm came off and I wanted to know if I can just get a new nut or do I have to replace the whole arm?
This is from a automatic 4x4 '98 Chevy Blazer.
Thanks for all the help!
Guest
Posts: n/a
I guess your not using it right now so hit it with PB blast for a couple of days also when you do put a wrench on it try jam a screw driver some place to stop the arm from moving. I worry that the pressure your going to have to apply might break something expensive inside. If it feels like somethings about to break see if you can do it some other way, with it still attached. Maybe cut the stud of with angle grinder and drill it out in place.
