shift solenoid problem
Old Jun 30, 2011 | 03:55 PM
lokiua4's Avatar
lokiua4 is on a distinguished road
Default shift solenoid problem
i have a 98 blazer and today i decided to change the tranny filter in today(what a ****ty idea that was!!!!)after a few hours of fighting to get the pan back in i finally got it back on and took it for a test drive and now i have a check engine light on.so i scanned it and it comes up as a shift solenoid.my question is do you think i broke something in the progress of doing this or just knocked a wire loose.i don't want to have to pull that pan off more than one more time.
thank you in advance for any tips or info
Old Jun 30, 2011 | 04:14 PM
step66's Avatar
Well,you may have caused an issue if you stretched a wire or otherwise abused these solonoids while trying to put the pan back on. They are very sensistive! I encountered the same issue last summer,but while I did not have any problems getting the pan off or back on(and went as gently as possible) my 97 developed a similar problemccaisional hard 1-2 shift and no OD! So: had to drop the pan AGAIN(after replacing the TPS!)to swap out the bad one,and has worked fine since! And I got to change my tranny fluid twice in one month! Search this site for your symptom and you will find the answer!
Old Jul 1, 2011 | 01:36 PM
hertz20's Avatar
hertz20 is on a distinguished road
Those connectors on the solonoids break off VERY easy, A Plug on mine broke off like nothing when i pulled the valve body to replace it and the separator plate.
also if you unplug a connector with the battery terminals connected, it throws on code instantly and stays on untill you clear it.
Old Jul 2, 2011 | 02:25 AM
kristoph30's Avatar
kristoph30 is on a distinguished road
I have the deep pan on my 2000. I had to jack the trans up to get enough clearance to get the pan on and off without damaging the solenoids.
Old Jul 2, 2011 | 04:08 PM
step66's Avatar
Yeah,I had to unbolt the rear trans mount (not completely) in order to raise the trans enough to pull & replace the pan on my 97 without damaging (I had hoped,the solonoids)
and when I encountered the problems-I did the exact same thing again-and this time with no issues...I guess the old plastic units fail at the slightest touch,since being subject to so much heat...What a pain! But easy enough! Good luck!
PsychoGMRS
Apr 10, 2019 07:08 PM
Tony H
Jan 21, 2011 10:11 AM
TheBlaze2001
Oct 19, 2010 09:26 PM
Tony H
Feb 23, 2010 08:09 AM
god_zilla00000
14
Jan 5, 2010 05:26 AM
