Shifter handle.
Old Dec 28, 2014 | 06:21 AM
vetteandblazerman's Avatar
vetteandblazerman has a little shameless behavior in the past
Default Shifter handle.
Does any one know how to remove the shifter handle on a 99 blazer, centre console mount , auto trans.
Looks like a clip of some kind on the back of the handle, but what to do with it, push,pull,twist.
Thanks in advance.
Happy New Year.
Old Dec 28, 2014 | 09:05 AM
perumotors1369's Avatar
perumotors1369 is on a distinguished road
go in the slot with a pick or very small slotted screwdriver and pull it straight out. Upon re-installation, I find it helpful to take a pair of pliers and slightly bend the open end in slightly and re-install..Jerry
Old Dec 28, 2014 | 10:16 AM
Thanks buddy,so it s just a type of circlip then.
Old Dec 28, 2014 | 11:34 AM
yepper-pry it out and raise the handle up to remove...whats you up to anyways....Jerry
Old Dec 28, 2014 | 11:49 AM
Well the shifter will not move into 1 or 2, just put it in d and its works normally. I went under and disconnected the cable from the trans , still the same so there must be a problem in the console. Hence the need to remove the shifter handle. Vehicle has been like this for 6 years or so , figured in the holiday break to fix it, if i can.
Old Dec 28, 2014 | 04:03 PM
gotcha..wonder if the issue is with the cable-seen that before..Jerry
Old Dec 28, 2014 | 04:41 PM
Have you? What maybe its stretched or frayed inside the tube?
Have i seen your name on some other forum before buddy?
Old Dec 29, 2014 | 07:23 PM
probably, I've been tinkering on Blazers/Jimmies for years..Jerry
Old Jan 3, 2015 | 10:09 AM
Smile
Well buddy, i fixed the problem i had to remove the shifter handle for.
Inside the console there is ratchet/detent plate, a stud moves on this ratchet when the shifter is moved, a tiny spring holds this stud on the ratchet, im my case the spring had come off allowing the stud to come out of place, 2 min fix to repair, took longer to get console off!
This may help you in future.
matthewp
Apr 4, 2021 09:16 PM
jasedude
Nov 24, 2010 04:03 PM
rbcar1
Dec 13, 2009 10:20 AM
speeddemon560
Mar 9, 2007 01:00 PM
C5Longhorn
Feb 28, 2005 03:21 AM
