slow power
Old Feb 3, 2019 | 11:45 AM
tam_1973's Avatar
tam_1973 is on a distinguished road
Default slow power
ok i turn the key on and nothing wait a min or two and the lights and buzzers come on i turn the key to start it and lights go out and nothing please your thoughts thanks
Old Feb 3, 2019 | 12:56 PM
Have you checked the easy stuff like the battery? Could the ignition switch is bad? What year and model?
Old Feb 3, 2019 | 01:22 PM
tam_1973's Avatar
95 blazer battery is good
Old Feb 4, 2019 | 03:30 AM
How did the Battery check out?
Voltage without load?
Voltage with applied test load?
We're coming back to the battery as it would be typical for a dead or dying battery to have this symptom.
I've seen this particular behavior before in cold weather. While when warm the battery was just able to start when out in the cold the battery looses part of it's performance. Switching the truck on yielded nothing at first. The load applied was sufficient to warm the battery to come slightly to life but it failed cranking as yours did.
That's why it would be important to know the voltages without and with test-load.
Old Feb 4, 2019 | 12:04 PM
go chevy's Avatar
Another small possibility could be bad battery cables??? Corrosion on the terminals connecting to the battery??? Just a thought
Old Feb 4, 2019 | 12:07 PM
newguy's Avatar
If your sure about the battery check and clean all connections. Battery, alt. starter and grounds
dhud64
Mar 2, 2015 05:55 AM
cking192
Oct 27, 2013 12:08 PM
blazin_j
Nov 1, 2009 07:13 AM
SDimeBlazerlady
Dec 30, 2006 03:43 AM
ste
Aug 8, 2006 03:19 PM
