Smoke coming from cassette player HELP!
Old Jul 7, 2012 | 06:35 PM
lannon_j's Avatar
lannon_j is on a distinguished road
Default Smoke coming from cassette player HELP!
2001 Blazer. The gauges on the dash, and radio werent working, so i replaced the fuses and it worked. But then the cassette player started smoking. So i went back into AutoZone and the guy told me there may be a wiring problem with it which would of caused it to blow a fuse. Anyone else ever hear of this happening? Need help on what to do, and if its an easy fix.
Old Jul 8, 2012 | 08:02 PM
jaked up's Avatar
jaked up is on a distinguished road
traceing wires is never an easy fix so in no way shape or form will it be easy. the frist question i have is do you use the tape player bc if you dont take it out as it maybe a short in the player itself. 2 if you do want to still be able to use the tape player you will have to track the wires from the player to see if there are any breaks or kinks in the wire. in order for u to do that you will have to remove the center console the cover plates under the dash and most of the dash itself
lityjohn701
Oct 23, 2015 07:47 PM
NCRD1331
Jul 10, 2013 12:21 AM
lilebes
Sep 9, 2011 02:48 PM
Luca1Blazer
Jun 12, 2007 04:11 PM
twei
Apr 24, 2007 11:12 PM
