Smoke from steering column
Old Sep 6, 2009 | 01:50 PM
J_man01's Avatar
J_man01 is an unknown quantity at this point
Default Smoke from steering column
ok I posted about my right blinker staying on typed left but meant right. My brake lights would come on by themselves. I looked around at other postings to get some ideas. Well then the column started smokeing and when i turn the right signal on now i here a buzz from the relay in the dash. When the truck is off if I step on the brake pedal the SES light comes on. I took the dash and column apart and havent seen anything yet Im thinking the brake switch or turn signal switch. I cant find any diagrams but the previous owner put rear mounted fog lights and a chargable flash light in the back they tapped into a pink wire at the harness connector going into a computer. Could that be part of the prob i noticed a pink wire going into the signal switch..
Old Sep 6, 2009 | 05:11 PM
Biohazed's Avatar
sounds like you have a grounded out wire. could be a wire going into the Multi-fuction swich i would trace them all back and make sure they have no damage and also test the wire for resistance
Old Sep 7, 2009 | 11:51 AM
J_man01's Avatar
OK where is the Multi-switch located. I'll start there
Old Sep 7, 2009 | 03:20 PM
Biohazed's Avatar
its the switch were the turn signals/wipers/hazard/ cruise control is located on the column
Old Sep 7, 2009 | 04:49 PM
amazinnblazin's Avatar
amazinnblazin is an unknown quantity at this point
Tell your steering column it's gonna die from cancer if it keeps on smoking
Old Sep 8, 2009 | 08:27 AM
x02050's Avatar
x02050 is on a distinguished road
Default Smoke
I had the same problem... smoke from the steering column area. Had the multifuntion switch replaced and it fxed the problem. If I remember correctly,I ingnored the smoke for a longtime until my brake lights failed, replacing the multifunction switch fixed both issues. Not an expert, but that is my story.
Old Sep 25, 2009 | 08:16 PM
J_man01's Avatar
Problem fixed and wasnt as hard as i thought it would be
Old Sep 26, 2009 | 01:07 AM
old skool luvr's Avatar
isn't it nice when that happens.
tammikm
Aug 25, 2006 03:26 PM
RdizzLe
Jul 11, 2006 05:48 PM
RdizzLe
Detailing
Jul 10, 2006 03:41 PM
keithscianna
Jun 11, 2006 10:12 PM
juliensales
Mar 29, 2005 12:16 PM
