smoking
Old Mar 31, 2012 | 12:24 PM
blazernut2's Avatar
blazernut2 is on a distinguished road
Default smoking
1995 jimmy 4.3 smokes out the exhaust smells like anti-freeze
Old Mar 31, 2012 | 01:22 PM
50lb_cat's Avatar
Check your oil cap and see if there's coolant on it. Its probably the lower intake manifold gasket. These trucks are notorious for having them fail. Its not a hard job to replace it, just takes some time. Make sure you use the updated fel pro gaskets, that are made of metal.
Old Apr 1, 2012 | 05:10 AM
DySfUnCtIoNaL's Avatar
DySfUnCtIoNaL is on a distinguished road
This.
Old Apr 3, 2012 | 08:38 PM
blazernut2's Avatar
Default smoke
hoping to not have to do it
Old Apr 3, 2012 | 08:40 PM
blazernut2's Avatar
Default smoke
thanks will get on it
Old Apr 6, 2012 | 01:38 PM
The Felpro new design, (steel/rubber sandwich type) gasket is not available for CMFI engines, (late 1995 and older). If you have a late 1995 with CSFI, then use the Felpro MS98002T gasket set. On both engines, make sure you clean & seal the lower intake manifold bolt threads, and the threads in the cylinder heads. Then follow the tightening sequence and torque specs.
Old Apr 7, 2012 | 09:09 AM
midnightbluS10's Avatar
midnightbluS10 can only hope to improve
My stock LIM gaskets lasted somewhere around 150k miles. Stock gaskets will work fine.
NOs
Jan 22, 2010 12:47 PM
DucatiKoenig
Nov 1, 2009 10:57 PM
roberfell
Oct 27, 2007 07:51 PM
FemmeVamp
Aug 29, 2007 12:13 PM
MsRandi
Mar 10, 2007 03:52 PM
