Snap, Crackle, Pop!! Indent bearing worn
Old Mar 31, 2025 | 01:15 PM
mugenmundo's Avatar
mugenmundo is on a distinguished road
Unhappy Snap, Crackle, Pop!! Indent bearing worn
As many of you have read my previous post on replacing worn-out bushing and pins, I now tackle the passenger side door issue. I have pushed this off as the passenger side door seldomly gets used. But in any case, the door indent bearing “You know, the thing that holds the door in multiple positions while its open" is seized. When you open the door, the bearing makes an awful popping sound, and it prevents the door from swinging open without a fight. I have ordered the parts to repair it, however it's a bigger job then the pins and bushings. Has anyone ever done this? Is replacing the bearing pin required, or can the drive rivet and bearing only be replaced? I have removed the spring for now to allow ease of door operation, although the door does flop in the wind as there is nothing holding it in-place. I don't recommend this as your passenger can accidentally hit a car parked next to you.
see pin replacement post: https://blazerforum.com/forum/2nd-ge...e&utm_content=
Old Apr 1, 2025 | 06:21 PM
I've never heard of this. Good luck and keep us posted.
Old Apr 2, 2025 | 02:17 AM
You may want to post a picture before and after the fix. It will nicely explain the repair.
Old Apr 3, 2025 | 10:41 AM
mugenmundo's Avatar
This is the bearing I am referring to. As you can see, I removed the spring temporary.
Rusted Right side Bearing no spring
Left side working bearing with spring
Old Apr 7, 2025 | 09:08 AM
mugenmundo's Avatar
Parts are in!! See pictures for GM part numbers.
OEM part numbers
OEM part numbers
Old Apr 10, 2025 | 04:13 AM
That's great! Thanks for the pictures and numbers. I have to fix one door as well.
blazen_red_4x4
Jan 28, 2021 12:45 AM
blazen_red_4x4
Jul 11, 2014 03:25 PM
phatso_99blaz
Feb 27, 2013 08:18 PM
vortec bowtie
Mar 31, 2012 01:11 PM
big armo
Jan 23, 2012 08:39 PM
