Sneaky IAC
Old Nov 17, 2010 | 03:31 PM
blzR's Avatar
blzR is an unknown quantity at this point
Default Sneaky IAC
Just wanted a quick shout out if you are expierencing a high fast idle.
I cleaned out the TPS,MAP,IAC,EGR,PCV,throttle body,checked for vac leaks
and after all that,curse words still filled the air. So next i went after the now pristine
IAC and found it was seized up real good & tight.
My 2cents of the day;just because it's clean doesn't equate functunalbility(sp).
Old Nov 24, 2011 | 03:02 AM
tallhorseman's Avatar
tallhorseman is on a distinguished road
Exact thing happened to me. If your rig sits up for a while and fast idles when you finally start using it again, check for a froze-up IAC!
Old Nov 28, 2011 | 10:48 AM
Kknd310's Avatar
Kknd310 is on a distinguished road
so im having a high idle problem after cleaning my throttle body, and im thinking its my IAC. how would u know if its good or bad? i can push the valve in but it took a good amount of force to get it in back i was scared id break it when pulling it out. is this normal? or has it finally frozen up?
Old Nov 29, 2011 | 10:55 AM
I think if I had it to do over again, and I wanted to test it, I would remove it from the throttle body, reattach the plug to it, have someone turn the key on, and see if it moves. I would be careful to not let it run but a second for fear of damaging it though.
If it did move you could at least rule it out as being your problem, but if it didn't it still could be good but not getting the command to move from the computer for some reason.
boscoedoodle
Nov 4, 2009 09:48 PM
Whutdidyousay
Oct 16, 2007 09:50 PM
jbeanz
Jul 23, 2007 02:26 AM
Mbastet99
Aug 25, 2006 09:55 PM
ron36535
Jan 23, 2006 12:06 AM
