which socket for sensor removal?
Old Mar 16, 2019 | 12:34 PM
puttster's Avatar
Default which socket for sensor removal?
I have a P0155 code (bank2 sensor1, Passenger side) and ordered a sensor. Q: what kind of socket gives the best leverage for loosening up the sensor? It looks pretty tight in there.
Old Mar 16, 2019 | 01:04 PM
cleburne red's Avatar
It's a 7/8" I believe. They sell a special socket for O2 sensor removal. It's basically a 1/2" drive 7/8" deep socket with a slit down the side for the sensor wires to stick out.
Can't remember which sensor position it was, but I had to just use a 7/8" open end wrench, there wasn't enough room between the sensor and floor board for the ratchet head
Old Mar 16, 2019 | 04:39 PM
puttster's Avatar
There are several styles of sockets with the slots, I was wondering which one. My sensor looks like this
I copied the pic from @Abbyblzrxtreme . She couldn't get the special socket to work so she had to cut the wire and used a 7/8 to break it loose
Old Mar 16, 2019 | 05:25 PM
That works for removal, but you still gotta get the new one in. So you'll need the sloted socket, or an open end wrench
Old Mar 16, 2019 | 05:49 PM
I find the best is to soak the crap out with some good old wd... then the wrench... it's all in the soaking...
Old Mar 16, 2019 | 06:43 PM
odat's Avatar
If you needed or wanted too use a wrench why would you need to cut the wire, can't you just unplug it, and if you wanted use the box end slide the wire thu the box end.
Old Mar 16, 2019 | 06:45 PM
I guess depending on where you live, they can get quite stubborn, huh? I always forget the kinda rust y'all gotta deal with up there. I've never had any problems getting O2 sensors out, even 20+ year old ones!
Old Mar 16, 2019 | 09:54 PM
puttster's Avatar
Have you done it this way?
Old Mar 16, 2019 | 10:12 PM
odat's Avatar
Yup - I also own the socket combo kit that Orielly sells for the O2 sensors
Old Mar 16, 2019 | 11:10 PM
GeorgeLG's Avatar
