which socket for sensor removal?
Old Mar 20, 2019 | 04:41 PM
puttster's Avatar
Originally Posted by odat
If you needed or wanted too use a wrench why would you need to cut the wire, can't you just unplug it, and if you wanted use the box end slide the wire thu the box end.
My sensor arrived today.
Odat, If you unplugged the connector on yours and slid it through a 7/8" socket, you need to tell me - and the world - how you did it.
Old Mar 20, 2019 | 07:20 PM
puttster's Avatar
Job is finished in 30 min.
Engine running only a minute or two, a few sprays of PB Blaster and a plain ole 7/8" open end wrench. The key for me was to come at the sensor from behind the exhaust pipe, where there is more room, and you can push the wrench maybe two or three inches, which is enough to loosen the sensor. (Also, my Xtreme has 60K of salt and rust -free driving, that might have helped.) Thanx and a tip of the hat to Abbyblzrxtreme who preceded me on this project.
I did not reset the sensors, seems like I read that was unnecessary.
On edit:: SES light turned itself off. Good to go!
Old Mar 21, 2019 | 07:40 PM
2001ZR2's Avatar
I used the O2 sensor socket from Harbor Freight but as others have said it's all in the soaking.with Penetrating Oil.
joshkayx
Oct 29, 2018 08:06 PM
richjoe
Aug 31, 2013 06:34 AM
liz's blazer
Feb 3, 2012 11:37 PM
dsevern
Aug 12, 2011 10:39 AM
MeidleinA
Dec 19, 2005 10:05 PM
