speedometer, odometer and cruise control
Old 03-22-2012, 03:00 PM
newguy's Avatar
Default speedometer, odometer and cruise control
none of them working, any help? fuse?
Old 03-23-2012, 04:27 AM
newguy's Avatar
Anyone?
Old 03-23-2012, 06:36 AM
pettyfog's Avatar
"What functions depend directly on the VSS signal, Alex..."
What unusual happened just before? Either VSS sensor or wire to
Old 03-23-2012, 07:45 AM
newguy's Avatar
Nothing unusual happen before, bought it this way
Old 03-23-2012, 07:49 AM
pettyfog's Avatar
Well, ohmmeter and the above chart will give you a start.
Old 03-23-2012, 08:24 AM
newguy's Avatar
OK, thanks Petty, you`ve been a big help with stuff here
Old 03-23-2012, 08:40 AM
chris015's Avatar
chris015 has a spectacular aura aboutchris015 has a spectacular aura aboutchris015 has a spectacular aura about
I know my 1st gen has a fuse for the cluster. It blew and only my speedometer and tac wasn't working. everything else was. On mine its a 20 amp fuse,I dont remember what it was labeled as. Check all you're fuses before digging into it.
Old 03-23-2012, 08:53 AM
newguy's Avatar
Chris, easiest rt first, always. Thanks
Old 03-24-2012, 10:59 AM
motorcity blazer's Avatar
motorcity blazer is on a distinguished road
on a 98 if it has a digital dash it will be fuse #3 on the driver side fuse panel inside the door jam. For what its worth pull the fuse and see if your gauges work. I know it sounds strange but mine did the same thing and I just pulled that fuse and all my gauges worked again. At the sacrifice of cruise control of course.
Old 03-24-2012, 11:53 AM
newguy's Avatar
Pulled the number 3 fuse, no change
Quick Reply: speedometer, odometer and cruise control
