Spider Injecter?
#21
Both tests failed. Provided voltage drop and ground at the pump are good, you need a new fuel pump. AC Delco or Delphi only, don't waste your time or money on aftermarket stuff. Don't forget to check Amazon & Ebay.
#22
![Icon Bunny](https://blazerforum.com/forum/images/smilies/icon_bunny.gif)
#25
From post #9:
If it fails one or both tests, [at the service port] pressure and leakdown must be tested at the fuel filter outlet to determine where the problem is. All pressure and fuel flow must end at the tester. While the pump is activated, pressure must be 73psi to 108psi and it must remain above 55psi for at least 10 minutes after the pump shuts off.
#27
So the pressure loss is only due to the Regulator doing its job. The fuel pump puts out more pressure than needed to maintain an adequate flow rate for all conditions.
Hope that explains it.
#29
Perfect explanation!
"All pressure and fuel flow must end at the tester."
Maximum pump output pressure=dead head pressure. (no fuel allowed to the engine)
The link in post #19 lists all of the parts that you will need to make the adapter, so you can check maximum pump output pressure, (dead head) and leakdown. After you do the tests explained in post #19, post all four readings.
#30
Yes. When fuel pressure overcomes spring pressure, the valve plate opens, fuel pressure drops, and the excess fuel & pressure is sent back to the tank via the return line. When spring pressure overcomes fuel pressure, the valve plate closes, fuel pressure rises, and the cycle repeats.
![Name: Fuelpressureregulator.jpg
Size: 14.6 KB](https://blazerforum.com/forum/attachments/2nd-generation-s-series-1995-2005-tech-41/31321d1501271438-spider-injecter-fuelpressureregulator.jpg)
The green arrow on the left is fuel entering the regulator after it leaves the fuel metering block, (the regulator is downstream of the injectors). The arrow on top is fuel returning to the tank. The vacuum connection is exposed to manifold vacuum inside the plenum, (no vacuum hose is necessary). When manifold vacuum is high, (idle & cruising) the spring is compressed and fuel pressure drops.
