spitting
Old Jan 27, 2007 | 06:54 PM
KLBlazer07's Avatar
KLBlazer07 is an unknown quantity at this point
Default spitting
Just a quick question.. it seems sometimes when im driving/taking off it seems to spit a bit like it will be fine and all of a sudden it will just spit/putt for a few seconds then be fine again.. any ideas what it could be?
Old Jan 27, 2007 | 06:58 PM
drperry's Avatar
Default RE: spitting
plugs/wires/fuel filter are the first things to check when this particular issue happens... What's the mileage? You might be able to rule out the wires that way...
Has it just started recently? Could be a bad tank of gas...
Old Jan 27, 2007 | 07:07 PM
KLBlazer07's Avatar
128 000km
Its been doing it for a bit.
Old Jan 27, 2007 | 07:16 PM
drperry's Avatar
Try changing the fuel filter first... The filter itself is fairly cheap, and was easy to change on my old Lumina, don't know about the Blazer's yet, lol, but should be easy enough to do, if you've got a Haynes manual, or similar, it'll help...
Plugs & fuel filter first, then if it still does it, we start digging deeper, lol.
When were the plugs last changed? Might be able to get away with doing one or the other if you're strapped for maintenance cash, but better to get 'em both done...
Old Jan 27, 2007 | 07:19 PM
KLBlazer07's Avatar
Im pretty sure its time for plugs to be changed. Ill do both. How much do filters usually run?
Old Jan 27, 2007 | 07:29 PM
KLBlazer07's Avatar
Any other things you guys can think of?
Old Jan 27, 2007 | 08:39 PM
drperry's Avatar
I generally buy AC Delco filters for everything, and they've all cost me less than $10, and generally less than $5... Just don't buy them at the stealership, lol
Old Jan 27, 2007 | 09:40 PM
KLBlazer07's Avatar
Im gonna do cap and rotor as well.
big_bear2009
Mar 4, 2012 07:28 AM
KLBlazer07
Feb 12, 2007 06:37 PM
