squeaky Blazer
squeaky Blazer
Whenever i start moving before i hit about 15 to 20 mph my blazer makes this loud squeaky noise, i thought the shock bushing were dry rotted so i sprayed them with some wd-40 but that didnt work. Any suggestionS? im going to take it to my buddys shop and put it on a hoist, just wondering if anyone has any tips b4 i replace everything. Thanks!
RE: squeaky Blazer
Is it a constant squeak, more of a squeal almost? If so I would check your squealers on your brakes.
On another note, I had squeaks in my front end that seemed to be only around low speeds, but that was only because that was the only time I was going slow enough to hear them. Anything above the 15-20mph that you mentioned and the road noise was enough to overpower the squeaks. I just recently sprayed my control arm bushings and sway bar bushings with some silicone lithium spray and my squeaks went away.
RE: squeaky Blazer
I greased my lower ball joints and my squeak went any. Grease all your zerk fittings.
RE: squeaky Blazer
i greased all my fitting yesterday and the squeak was still there, Where are the squealers on my brakes?
lizardking88mph
10-30-2011 08:50 PM
