Squealing noise coming from the engine.
Old Jun 17, 2012 | 02:43 PM
nevwyn's Avatar
nevwyn is an unknown quantity at this point
Default Squealing noise coming from the engine.
I'm not sure what it is but out of the blue this morning I was woke up by this weird whining squeal around 5am. I didn't think anything of it as I'm in an RV park figured someones pump or generator had kicked on in one of the nearby units. Still hear it at 9am when I get out of bed, I go outside and its coming from my blazer.
Its not significantly loud but it has never made any noise like it before, I grab my keys start it up and it starts up fine after doing this for several hours. But I can still hear it whining when the motor is running.
Popped the hood, and disconnected the battery and it all stops. Hook the battery back up fire it back up with no problems and it starts whining again. It sounds like its coming from the drivers side of the engine but I could just be hearing it wrong.
98 blazer.
We found the problem.
Old Jun 17, 2012 | 02:52 PM
What was it coming from??? Did you pin point the source of the noise? Can you take a picture of the source? Really need something more to go on than what you have provided in order to help you out.
Old Jun 17, 2012 | 03:02 PM
nevwyn's Avatar
Okay, just happened to get lucky. Seeing as its Father's day I had been trying to get a hold of my dad all day for well wishes and he happened to call well I was poking at things.
Turns out the starter motor is spinning but not engaging the soleniod so it wasn't contacting after the engine started running.
dusktiger
Feb 5, 2015 05:28 PM
redbrawn
Apr 4, 2014 08:22 PM
RhysThePiece
Mar 25, 2011 11:40 AM
Hodad
Jun 7, 2009 04:30 PM
wolves0309
Sep 8, 2008 08:12 PM
