squealing noise
Old Aug 21, 2008 | 03:18 PM
wolves0309's Avatar
wolves0309 is an unknown quantity at this point
Default squealing noise
hi all
i have having a hard time to find out what this squealing noise is coming from.
it only happens in reverse. and im sure it is coming from the rear left tire
all the brakes/rotors are new (AC delco), and i have replaced both rear calipers(both needed to be done anyways since the rubbers were gone and not letting the wheel move freely)
so i am stumped, my last thought would be the e-brake?
any help?
thanks
Old Aug 21, 2008 | 09:23 PM
Default RE: squealing noise
Check the shims. I had a weird noise like this and it was just something about the direction of travel that made the rotor ride a bit closer to one side and it would scrap against the rotor. Drove me crazy for a bit. I don't know how many times I took everything apart.
If it isn't that, then it is possible that it is the e-brake. Watch out, the internal band is quite expensive if you have to replace it.
Old Aug 22, 2008 | 02:56 PM
wolves0309's Avatar
thank you Kyle
ill take a look at the shim
also was told the rubber band to replace is $300
Old Sep 8, 2008 | 08:12 PM
petty's Avatar
petty is an unknown quantity at this point
ORIGINAL: wolves0309
hi all
all the brakes/rotors are new (AC delco) revtek, and i have replaced both rear calipers(both needed to be done anyways since the rubbers were gone and not letting the wheel move freely)
any help?
thanks
When I was starting the car, it makes an annoying noise but as I drive, it does continues especially even when my car is warmed up. The belt isn't the problem I guess, could it be the alternator pulley bearing?
dusktiger
Feb 5, 2015 05:28 PM
redbrawn
Apr 4, 2014 08:22 PM
nevwyn
Jun 17, 2012 03:02 PM
RhysThePiece
Mar 25, 2011 11:40 AM
Hodad
Jun 7, 2009 04:30 PM
