Starter engaging when shifting and driving
Old Oct 1, 2021 | 08:50 PM
Talk about going back in time...
Sorry I can't help, but maybe start a new thread din the appropriate section for a faster response.
but I'll go with the sensor needs to be swapped for a proper one...
Old Oct 1, 2021 | 10:52 PM
GeorgeLG's Avatar
Do you have and know how to use a digital multimeter?
One of a few things is happening:
1) The ignition switch or steering column wiring for the switch is malfunctioning
2) Something else is putting 12V on the purple wire that energizes the starter relay coil and passes power to the started. This would most likely be a wiring short or the trans range switch
3) something is putting 12V on the starter power wire. This would not be enough to start the truck but might kick the started gear into the flywheel.
While not the most likely, the easiest to rule out is #1. Start the truck and then pull the crank fuse and see if this keeps happening. If it still happens then its not the ignition switch or its wiring out to the relay box.
Report back and we will keep going if its not the ign switch.
George
LuckyAce
Jun 28, 2017 04:12 PM
paco
Apr 4, 2011 11:12 AM
Tortex53
Oct 27, 2010 11:23 AM
chappie74
Oct 18, 2010 09:51 PM
harley-mac
Aug 10, 2010 05:21 AM
