starter trouble
![Angry](https://blazerforum.com/forum/images/icons/icon8.gif)
I'm having some problems with my 96 Blazer. I replaced the starter about 5 months or so.Three days ago I went to start it and it cranked but then stopped. Now if I try and start it I get nothing not even a clicking noice. The purple wire was off so I reconnected it and I still get nothing and today I changed the relay. Can someone please help me fix my problem befor I lose my mind thanks!!
that's all I can got....
Thanks 69chevelle. I'll check the fuse again. Also when I had it at a garage for new spark plugs they went and cut the rubber from the wheel well which now some parts are expossed. Now if the starter got wet could that have screwed the starter up? Thanks
I recently changed the neutral safety switch on my 96 Blazer and the dash has that it's in neutral when the shift is all the way up. What can be the problem,does the shift cable need adjustment or does the safety switch need to be repossioned. Can someone help me solve my cash eatin blazer problem. Thanks
a neutral safety switch is desinged to only allow your starter to engage when it's in park/neutral.
could be the same problem as to why your truck won't start.
try starting it in neutral
I personally have never touched my transmission or neutral safety, so I am not sure how it's designed. someone else will pipe in.
thanks I'll try that again!
I guess I should also add...
test to see if you are getting power at the small wire on the starter when the key is in the start position(will take two people) that will tell you if your truck is telling your starter to turn or not
or you can get a piece of wire and touch power to the small wire on the starter and your truck should start, that will eliminate the starter.(make sure your truck is in park)
