starter won't engage
Old Jan 31, 2008 | 02:08 PM
snowman's Avatar
snowman is an unknown quantity at this point
Default starter won't engage
[:@] 98 Blazer 2dr , washed about 3weeks ago, since then all it does is click,click then it will
start. But this morning it went down to -36c, and was plugged in for 3 hours, and all it did
was click,click,click. I would like to know how to get the moisture out of the starter with out
removing it. thanx.
Old Jan 31, 2008 | 02:10 PM
hillbillyinOhio's Avatar
Default RE: starter won't engage
i wouldnt lean towards water in starter. Check battery cables first and make sure they are tight with no corrosion in battery.
Old Jan 31, 2008 | 02:14 PM
snowman's Avatar
checked all connections, new battery put in. When outside temp. is not so cold it starts, but this is the first time no starter engagement.
Old Jan 31, 2008 | 07:36 PM
Kordog's Avatar
Kordog is an unknown quantity at this point
The starter is in need of replacement. They usually get a dead spot and the only way to fix it is to replace it. HTH
Old Feb 1, 2008 | 11:16 AM
snowman's Avatar
[sm=smiley25.gif]The temperature this morning was only -11c, and it started no problem. Called a starter
shop and the guy said the starter is okay. The starter just needs to be taken apart and the moisture removed from it, and cleaned. He said at low temps the the contacts are frozen and when temp rises to a certain point they are not frosted anymore. The guy also said when using a pressure washer underneath the vehicle, not to directly point at the starter. So I will go that route. I will post the results when corrected.
jdmmario
Oct 25, 2014 06:25 PM
Eagleridge5
May 29, 2013 03:53 PM
lazer2000
Sep 16, 2012 11:16 PM
burfdogg
Jul 3, 2011 08:52 PM
zl1427bowtie
Dec 3, 2004 01:50 AM
