Steering Wheel Play
Old Mar 27, 2008 | 08:38 PM
Stopphn's Avatar
Stopphn is an unknown quantity at this point
Default Steering Wheel Play
When Idrive my steering wheel seem to have a alittle play. I can move it side-to-side and the truck will keep straight. Any suggestions?
Old Mar 27, 2008 | 09:06 PM
98BlazerLT4x4's Avatar
98BlazerLT4x4 is an unknown quantity at this point
Default RE: Steering Wheel Play
I would get someone to turn the wheel for you while you get under the car and check the tie rod ends, pitman arm and I think Blazers have a rag joint too.
Old Mar 27, 2008 | 09:34 PM
Much of this is due to the steering gear (reciprocating ball) setup. There is an inherent neutral position. But regardless of that, you should definitely inspect the steering components. Idler arm is a good source of play along with the other suggestions above.
And yes, all s-series vehicles have a rag joint.
Old Mar 27, 2008 | 10:25 PM
Yea I forgot to say idler arm I actually replaced mine a couple days ago.
ethan.zick
Mar 19, 2010 12:09 AM
meatchief
Apr 8, 2009 07:04 PM
Kojak
Jan 23, 2008 06:28 PM
Turismo
Nov 8, 2007 12:25 PM
1996blazer
Sep 23, 2006 01:19 PM
